How to improve screenshots and change background color of photorender
If you are one of those people (like me) who are constantly take screen shots of your ProE models to paste into PowerPoint, etc, then I have some good news for you ;)
You can dramatically improve the way your models appear directly onscreen by using Photorender: View -> Model Setup -> Render Control. Click "Render Final Image" on the toolbar that pops up and see the difference! If you do a screen capture now it is going to look so much better.
The default background color for rendered images is black. Since you'll probably be pasting this image into PowerPoint and setting the background transparent, this is not good. To change the background, click "Modify Render Settings" on the rendering toolbar, and then check the "Render Room" box. Close that dialog and click "Modify Room Settings" on the render toolbar. Click on one of the walls and set the color to white, do the same for the ceiling and floor. Now render the final image and you'll have a white background instead of black.
You can of course do much more detailed renderings, but just doing the basic steps above to render the image directly on your screen will make a world of difference in any screenshots you take, and the process takes all of about 15 seconds ;)
I wish someone had told me this a long time ago!
I am posting this tip after seeing the same question ("how do I change the background color of photorender?") posted in thread554-7122 and thread554-102421 with no answer.
RE: How to improve screenshots and change background color of photorender
http://www.sprdesign.com
http://www.3dlogix.com
It's probably b/c I've been too lazy to figure out which settings would work right, maybe I was using too low of quality settings. Like I tried it yesterday with a jpg and the image looked really washed out. Probably very easy to fix in photoshop, but I am trying to eliminate as many steps as possible.
-Hora
