Tubing with variable profiles
Hi. i'm new to solidworks and was wondering how i would create a tube with variable profiles. like for instance, from 2"diameter to a 4" with a smooth transition.
using structural members has been neat but limited to one profile. any help would be great. thanks.
RE: Tubing with variable profiles
Flores
SW06 SP4.1
You can use the loft command or the sweep command. The sweep has 1 profile with as many guide curves as you need. The loft will essentially give you more control than a sweep.
John Graham CSWP
Mechanical Design Engineer
