abbrivation introduce for instrumentation
I have interfaced in my P&ID diagram to some abbrivation which I don't have any refrence to recognize them. for instance when I have PIA, It mean's pressure indicator with alarm. but I need a standard list which I can verify any abbrivation. any information will be highly appriciated.
RE: abbrivation introduce for instrumentation
Not to say that PIA is incorrect, it is just that I have never seen a tag PIA-xxx. It is usually PI, or PI and PAH/L.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
There is a separate forum, ISA (control systems engineering) Code Issues Forum, that covers similar issues.
Home > Forums > Engineering Codes, Standards & Certifications > Engineering Codes, Standards & Certifications
Dan
