Best way of impedance measurement ?
What is the best way to measure the impedance(S11 with network analyzer), (for example the output matched impedance of a PA) at high frequencies (above 5 GHz) with the minimum errors due to low impedance, parasitic capacitance, and soldered connector influence ?
RE: Best way of impedance measurement ?
You do need a network analyzer! Homebrew boxes do not work at those frequencies. Unless you are very, very good in that part of the spectrum - and then you probably needn't ask...
Seen some network analyzers on eBay lately.
Gunnar Englund
www.gke.org
More specific, is there away to minimize measurement errors due to the measurement itself (deembedding) ?
1/4 wavelength is 15 mm. It is not easy. I would not even think of it. Someone else?
Gunnar Englund
www.gke.org
Measuring output impedance with a VNA is not necessarily a good idea anyway. The technique using a VNA back-drives an output. How representative is that going to be?
The thing you are trying to measure is source match or source reflection coefficient. One way is to use a long cable and sweep the input frequency. You then need a power or voltage detector on the output. The cable changes the reflected signal phase continuously as the frequency is swept. This method is good for wideband sources.
If you have a narrow band source then you need a directional coupler, a power meter and a sliding short circuit. This kit is more than 10x cheaper than a VNA and gives a better answer.
Sorry to barge in on this thread.  I am also interested in measuring impedance.  Is it possible to buy/put together from commercial parts, a network analyzer that measures in the visible range of the electromagnetic spectrum?
I have a liquid nano structure that I would like to analyze it's permeability and permittivity in order to perhaps explain it optical/light scattering/sound altering properties.  HP only sells them up to the GHz range.
I am a biochemist.  I do not have a clue.
