models for sand
models for sand
how to model sands in nonlinear fashion? Linear-elastic models and elasto-plastic with Mohr-Coulomb failure seems to me less acurate in many cases. What is your point of view or experience?
RE: models for sand
I think classical elasto-plastic model with strain softening behavior would be better, or other model introducing strain softening would also be ok. About the limit stress (failure) condition Mohr Coulomb or Druker Prager or Matsuoka Nakai will be ok.
regards,
sendy.
RE: models for sand
RE: models for sand
RE: models for sand
You're right that angularity of particles is one of the variables that could lead to the non-linearity of displacement field of sand layer. Other variables are the void ratio, the current (stress) pressure, grain size, and the constraint deformation of particle itself.
regards,
Sendy.
