mating problem
mating problem
I have a slide moving up and down in the vertical plane held with limit mate ( 0-500mm). I have another slide in the horizontal plane. I want to be able to control the movement of the horizontal slide when draging the vertical slide up and down (visa versa), basicly when the vertical slide is at the top it wants to meet the horizontal slide at right angles and when i drag it down they want to move away from each other.
RE: mating problem
RE: mating problem
RE: mating problem
