Measurement of Head Loss Across Trash Rack
Can any one one help me with a tricky issue of head loss measurement in an intake water station well with multilevel intake opening with trachracks. This intake station has 4 intakes at different levels and are provided with trashrack to prevent debris from entering th intake well. Water is discharged from the bottom opening. We need to provide instrumentation to measure the degree of blockage of each screen/trashrack.
Thanking you in advance.
Good day gives you happiness, Bad days give you experience. Count Both....
RE: Measurement of Head Loss Across Trash Rack
Didn't get you. Do you meas use of differential transmitter across screen or other wise?
Any way let me explain. This intake tower is surrounded by water all around so the upstream head for all screen is same. Similary on the downstream of screen is the well which is again common for all inake points. Considering this, is it still possible to measure the head loss across individual screen.
I hope I am clear.
I supposed what you are trying to do is detecte a fouled rack.
If the level behind them is common, then DP won't work.
Have you stood there are looked at a fouled rack? Is the level right behind the rack any different from the others?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
http://www.differentialpressure.com/
Google is full of others cheap to very spendy. You can get 4-20 Mill xmitters or switch alarms.
I would use 1" PVC pipe. Water will flow through it so you'll need some way to keep it clean. YOu may want to periodically back flush it from the screen wash system.
https://we
