Electric switch consultant
I am looking for an industry expert in the field of electric switches: someone with expertise through years of experience in spring materials, contact materials, contact platings, contact forces, arc energy theory, switch bounce, make-and-break characteristics, diagnostics, troubleshooting, etc.
Any recommendations would be greatly appreciated!
RE: Electric switch consultant
Do you need to hire this person?  If not, the area rep for your favorite switch company should be able to put you in touch with a good tech at their company.
Dan - Owner
http://www.Hi-TecDesigns.com
Normally that could work, but I'm trying to design out an OEM switch, therefore I'd expect no help from the switch manufacturer.  I need an independent consultant.
Define "switch". That could be anything from a 5VDC 100mA reed switch to a 15kV 5000A disconnect switch.
JRaef.com
Eng-Tips: Help for your job, not for your homework  Read FAQ731-376 pirate
I am looking at a switch that can handle 120VAC-277VAC, up to 8A steady state current.  The switch would control typical electrical loads found in a home.
Also compressor motors and other loads with a high starting current? How many ON/OFF cycles are you designing for? Is it manually actuated or is there some sort of mechanical actuator?
Gunnar Englund
www.gke.org
Load types are typically motor loads such as a fan or garbage disposer, or tungsten filaments in light bulbs.  My target is 200,000 minimum ON/OFF cycles.
