Turn Solidworks surface to a solid
I have a surfaced component - is there a way of converting it to a solid body?
Thank you for your help.
RE: Turn Solidworks surface to a solid
You would have to use the Knit Surface command
Insert > Suface > Knit & click Knit Surface
There is a try to form solid option on this command
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
You could also try the thicken command, assuming you have an enclosed volume.
John Graham CSWP
Mechanical Design Engineer
Run tools\Check make sure there are no gaps or open surfaces, along with general faults. If all those things check out then I normally do like Heckler suggests, Knit the surface and you will get the option "Try to from Solid". Check mark that and OK the command.
If you have any gaps, open Surfaces, or general faults, you will have to repair those first.
Best Regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
