Glycol Water Pumps Manufacturer
Dear friends:
I am designing an HVAC system requiring 30% (volume)ethylene glycol/ or propylene glycol water solution.
Do you know any water glycol pump manufacturer reated to this kind of cooling system?
Cooling water flow is 72 GPM, head 110 ft. H2O. temperature 54.00 ºF
Thanks in advance.
Schola
Thanks in advance.
Schola
RE: Glycol Water Pumps Manufacturer
Bell & Gosset,
Taco,
Armstrong,
Blue, Green and Red.
P glycol might be non toxic, but you could argue about the enviromental benefits as it requires more pumping energy and results in a larger performance degrade for most chillers and terminal equipment.
Having said that, I use P.glycol whenever there might be a crossover (domestic hot water) or if I'm concerned that someone might try and drink the glycol.
Is P.Glycol easier to dispose of than E.Glycol?
