chewing gum
chewing gum
Dear All ,
We would solve chewing gum in manufacturing reactors in chewing gum factory. At the same time , We want to solve chewing gum in textiles . We tried solvent chemicals , we caught succes but disadvantage easily evapored.
Pls help us ,
Kerem
Pls help us ,
Kerem
RE: chewing gum
Gum on clothing can be put in a freezer and then scraped off.
Kerosene and ethanol dissolve gum, as probably do a lot of other solvents. When cleaning synthetic fabrics, test the solvent on an invisible part of the cloth to make sure the solvent doesn't dissolve or otherwise destroy the fabric.
The gum base can also be melted at a temperature of about 115 °C.
RE: chewing gum
I made mistake . We want to dissolve gum in Factor?ES boiler . Factory produce gum , after production a lot of gum on boiler . We want to solve this gum with chemicals . Any body have solution ? What chemicals do we use?
Best Regards,
Kerem SENCAN
RE: chewing gum
Not sure if you can find an non-hazardous solvent.
RE: chewing gum
