I am looking for a solvent for a vulcanized RTV gasket
There are two plates (Mg alloy+A380) that are connected by RTV silicone. I need to dissolve the gasket in order to measure the weight loss of the plates.
RE: I am looking for a solvent for a vulcanized RTV gasket
Cyclohexane is very flammable and has a low boiling point.
Silicone manufacturing equipment is cleaned with hot
toluene. This is for a closed system.
Whatever you use you will end up having to do some mechanical cleaning to get the residue off.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Rust never sleeps
