4140 replacement
4140 replacement
4140 replacement
I am looking for a material with a lower permeability than 4140. The application is for a magnetic circuit that relies on leakage flux to function so the material must saturate at a lower value from the source magnets.
RE: 4140 replacement
Some ideas:
4340 has more alloying elements in it that would reduce permeability & saturation.
If you can cold work the 4140 more, that'll also achieve what you are looking for.
Some of the 400 series or duplex stainless steels might work too.
Good luck,
Mike
Thanks, do you know where I can get a BH curve for 4340 to fit in my model?
Why not make the part smaller to increase leakage?  Or build in a  controlled air gap?  Using alloys that are not manufactured to magnetic quality requirements to control you system is a bad idea.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Hi Gwjohnson,
Do you happen to have the BH curve for 4140? I've been searching for it and had no luck so far. I'd really appreciate it if you could share the info. My email is bzhang at dextermag dot com, or please post it here.
Bo
