Cooling Options for a Bearing
I am looking for alternate methods to cool the upper bearing of a motor.  Currently the bearing is designed to use 31 L/min (491 gallons/hr) of water through water cooling coils.  I am trying to find options that would reduce the amount of water used or another method.
some useful information...
the bearing: model EVEKU-07 by Renk
the motor: model ANVE-WT001 by TECO WESTINGHOUSE
(a three phase induction motor)
If you have any information that may help, please let me know.  Thanks!!
RE: Cooling Options for a Bearing
How are you planning on getting a cogent answer if you don't reveal the amount heat to be removed?
TTFN
You can review an air cooled bearing option. This would probably require some engineering modification to the existing bearing bracket and a re-design of the bearing itself to properly dissipate heat.
Possibly the least awful solution is to circulate water/glycol through the extant plumbing, and cool that with a radiator and a fan.
Mike Halloran
Pembroke Pines, FL, USA
Why add the glycol?
I2I
To keep the water from eating the radiator.
Mike Halloran
But that would require a larger flowrate to cool the same bearing which is the opposite of what he was looking for.
I2I
Somehow I got the impression the OP was talking about "cooling coils" embedded in the bearing housing, and using the water exactly once and dumping it, i.e. "water used".
Hey, I could be wrong; it happens every day.
Mike Halloran
It never crossed my mind that he may be dumping all the water, I just assumed that was a closed loop process.
I2I
If changing to a closed-loop cooling system, look at using a laser or welder chiller (refrigeration type cooler) instead of ambient radiator. You then set the water temperature just above condensation temperature (not to make water in the bearings) and remove more heat this way.
