rotate dimension
rotate dimension
Is there a way to rotate dimensions in a drawing? For instance if I do a vertical dimension , is there a way to have the dimension text be oriented horizontally instead of vertically.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: rotate dimension
Or to change dims individually, you could RMB on the dim, go to Properties, Display, and Override standards dimension display, and pick the middle option.
If you want to use ISO (or whatever standard you have for that matter), you can still overide the standard. Document Properties--Dimensions--Leaders.
John Graham CSWP
Mechanical Design Engineer
