EXPORTING LINE ATTRIBUTES
Is there a way to select a line and export (write to file) its attributes - I am really only after linetype, global width, LTS and colour.(for export back to a table)
The aim is actually to produce a drawing displaying all autocad colours and how they are printed (our printer is a little naff and some of the colours come out rather bad). In addition I was trying to display the different line types with various other variations (global width etc).
Do you have any ideas of how to produce such a drawing other than draw the lines, change the colours and write the text?
Cheers. Sean.
RE: EXPORTING LINE ATTRIBUTES
Any other thoughts?
Cheers. Sean.
Cheers. Sean.
A long while back, we created a drawing with all of those samples lined up together. Takes about 20 minutes.
"Everybody is ignorant, only on different subjects." — Will Rogers
I know a "ctb-tester". It's a dwg with 256 lines, each color. Do you need this?
L.
ADT 2004
ACAD 2002
Cheers. Sean.
L.
ADT 2004
ACAD 2002
Cheers. Sean.
