ProE template format into SolidWorks
I have a client that needs some drawings created. Unfortunately, their custom templates with their company logo are done in ProE. They sent me their template files, but I have no idea what I need to do to make them compatable with SolidWorks 2006. Does anyone know what I need to do? Do I just bite the bullet and recreate them in SolidWorks?
RE: ProE template format into SolidWorks
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
http
Chris
AutoCAD 06
Bit the bullet and recreate them in SolidWorks. That way you would have the properties set to your standards. You could even use your own tools to fill in the title block information, notes and revision blocks. Your data would be kept with the models. You may already have a format you could modify to match theirs.
We moved from AutoCAD to SolidWorks and spent more time trying to convert the AutoCAD template then it took to finally just redraw the template.
Good luck.
Bradley
Chris
AutoCAD 06
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
