Spline Selection
Spline Selection
How do I size and a select the right spline for a certain application? I know the torque, rpm and a starting shaft size. Any design books you can recommend? Thanks.
RE: Spline Selection
1. If you need to connect with an off-the-shelf part, like a coupler or yoke, look at whats already available. If this is going to be a production part, find out what profiles your suppllier normally deals with.
2. Generally the spline count goes up with load and/or rpm's. I'm not sure what the exact reason is, but it probably has to do with having a larger rood diameter for strength and more area to transmit torque.
Automotive splines are fairly standardized by diameter/tooth count, not fine or course.
If the spline is to be cut, the minor diameter needs to be at least the shaft diameter for 100% strength. If it is rolled it can be formed in the shaft diameter and provide up to about 85%-90% of shaft strength.
http://w
http
