RMS to DC conversion
kunalw (Electrical)
How to go for RMS to DC conversion.Any reference?
OPAMP oriented circuit will be preferable.
RE: RMS to DC conversion
there is a cool IC that perfoms RMS to DC conversion. It's from MAXIM ... I don't remember the right number but i believed it was MAX687 or something.... try it at www.max-ic.com.
If we have a square wave of zero volts to a unipolar peak of "E" volts (typical of much logic circuitry with zero and +5 volts) and some particular duty cycle, the average value of that waveform is E average which equals E times that duty cycle.
Then, having obtained the average, the root mean square voltage, call it E rms, equals E average divided by the square root of that duty cycle.
The average value is easily measured with any DVM and an RC low-pass filter. From that measurement, the RMS value can be calculated.
This appeared in Electronic Design for October 14, 1993 in the Ideas For Design section.
John Dunn
Ambertec, Inc.
-Crystal(Cirrus semiconductor).
-Maxim Semiconductor.
-Analog Devices.
-TelCom Semiconductor.
-Intersil Semiconductor.
-Teledyne Semicondutor.
-Fortune Semiconductor.
-ITRI/ERSO.
covers several different types of RMS to DC converts.
I like the Linear Tech LT1088 heat based device myself.
bobp
thanks for your advice.
the site recommended by you is quite useful
once again thank you.
s.rajendran
rajens@tr.dot.net.in
