Looking for lens that will collimate 4 led dies 2mm apart
I have an LED that has 4 1mm chips inside it, RGBA. When I use a standard luxeon LED lens the beam angle doubles because the led chips are all offset from the center by 2.5mm. It's a result of the light being reflected internally and exiting the lens not in a straight beam but more at an anlge. Without diffusion I can see the four separate sources on my projection surface.
I was wondering if anyone had any solutions for this probelm? I was looking at micro lenses because you could prossibly have a separate lens for each chip and keep them within the 2.5mm distance of each other.
The chips have to stay close for the color mixing, so to have 4 separate LEDs and 4 separate lenses creates too many color shadows because the LEDs are too far apart.
Thanks.
Thanks.
RE: Looking for lens that will collimate 4 led dies 2mm apart
TTFN
Who makes your RGBA LED? I'd like to give it a try.
- Thanks
