Allen-Bradley SLC5/-4 and Panelview 1000
I am designing a system with a SLC 5/04 processor which I will be connecting to a Panelview 1000 Via DH+. Connected to the RS-232 port will be a 22-SCM-232 serial converter that is connected to a Powerflex 4 and powerflex 70 drives.
What I need to know is, is there a way to connect to the SLC 5/04 via DH+ without disconnecting either the panelview or the serial converter.
RE: Allen-Bradley SLC5/-4 and Panelview 1000
If so you could put a drop line off of your main trunk line to connect to.
