Chromemoly vs St.St
Chromemoly vs St.St
Chromemoly vs St.St
Hi all,
Im a trainee engineer on my last year of a HNC so I still have a lot to learn, so any advice on the following would be helpful.
I would like some information on the plus and minuses of a stainless steel tubesheet vs. a CrMo tubesheet.  The item is a small u-tube de-superheater bundle.  However I do not have any technical information such as operating temp or operating pressure etc.  So I suppose any basic info would be helpful.  I will try and get more information off the customer if I can.
I have done some research and found out the following about CrMo ~ chromium provides improved oxidation and corrosion resistance and the molybdenum increases strength at elevated temperatures.  CrMo steels have a tendency to long term embattlement in the approx. 370 to 580 degrees Celsius range.
Jason
RE: Chromemoly vs St.St
Material selection for a heat exchanger is based on suitability for service (which means you absolutely need to know operating conditions and the environment), cost of material and availability of material.
Most likely for a desuperheater, you will need elevated temperature strength properties and corrosion resistance. In pressure vessel design, the allowable stress values for material selection plays a significant role provided the materials can handle the environment (potential corrosion issues).
