Update mass props macro
Anyone know of a macro that opens model files and updates the mass properties ?
Something like the 'OpenSave' macro.
It's a pain having to find which models haven't had the mass calculated and then doing each one individually.
bc
bc
RE: Update mass props macro
But I don't need it. Open dratf and go to the part. When you change dimensions of part - click 'save' and back to draft. Msss must be changed automatically. (SE18)
Look into the TreadTools macro available here:
http://www.barhamsoftware.com/SE_Tools/index.htm
You can use TreadTools in combination with the OpenSave Macro to achieve what you want.
Also here is the link to the SeGuruCool website:
http://www.geocities.com/segurucool/
I'd already looked at segurucool but couldn't find anything to do the job.
I'll try 'treadtools' and let you know if it does the job.
bc
