New in Postbuilder
New in Postbuilder
New in Postbuilder
Hi
I want add block in postbuilder, whitch will when the user run
postprocer from NX4 to popup an input box.
Is that possible?
RE: New in Postbuilder
Yes that is possible you can call executables with tcl. You could for instance use tk for the popup.
Can You write example how to do it?
sample that communicates thru a temp file you could also use arguments in a list. An alternative is to use the error handling variable in postbuilder to communicate between the two.
code in postbuilder:
set jr_prog_contour_number 2
exec $dir <<$jr_prog_contour_number [MOM_ask_env_var UGII_CAM_POST_DIR]agie_ct_v2.tcl $jr_prog_contour_number
# open a tempory file to get data from the ct window agie_ct.tcl
set filein c:\\temp\\tempct.txt
set invoer [open $filein r]
set data [read $invoer]
set CycleTime [lindex $data 0]
set WireLength [lindex $data 1]
set JobName [lindex $data 2]
external code sample called agie_ct_v2.tcl:
#!/bin/sh
# the next line restarts using tclsh\
exec tclsh "$0" "$@"
# this file starts a widget to ask for a cycle time
proc Main { } {
    global ct
    global wl
    global JobName
    global FilePath
    global platform
    global tcl_platform
    variable Thread "Main"
    global NumberOfContours
    global List
    wm title . "Rouwe Analysis Postprocessor"
    font create minetitle -size -24 -weight bold
    font create minesubt -size -18 -weight bold -slant italic
    font create minetxt -size -18 -weight bold
    font create mine -size -18
    label .msg  -font minetxt -wraplength 4i -justify left -text "Please enter agiePC parameters"
    pack .msg -side top
    # bottom of window
    button .dismiss2 -justify left -font mine -text OK -command "create_temp_file"
    pack .dismiss2 -side bottom -padx 1m -pady 1m
    # left and right middle of window
    frame .left
    frame .right
    pack .left .right -side left -expand yes -padx 10 -pady 10 -fill both
    set ct 01:00:00
    label .left.labeli1 -text "cycle time (hh:mm:ss)"
    entry .right.ct -width 7 -relief sunken -textvariable ct
    pack .left.labeli1 .right.ct -pady 3
    set wl 1000
    label .left.labeli2 -text "wire length (mm)"
    entry .right.wl -width 7 -relief sunken -textvariable wl
    pack .left.labeli2 .right.wl -pady 3
    set w .
    set font "mine"
    set List "job"
    if {$NumberOfContours < 1} {set NumberOfContours 1}
    for {set Index 1} {$Index<=$NumberOfContours} {incr Index} {
        set iso "iso$Index"
        lappend List $iso
    foreach i $List {
        set f [frame .$i]
        if {$i != "directory"} {
            set TypeOperation open
            label $f.lab -text "Select a $i file to $TypeOperation: " -anchor e
        } else {
            set TypeOperation directory
            label $f.lab -text "Select UG-nc file directory: " -anchor e
        entry $f.ent -width 20
        button $f.but -text "Browse ..." -command "fileDialog $w $f.ent $TypeOperation $i"
        pack $f.lab -side left
        pack $f.ent -side left -expand yes -fill x
        pack $f.but -side left
        pack $f -fill x -padx 1c -pady 3
    if ![string compare $tcl_platform(platform) unix] {
        checkbutton .strict -text "Use Motif Style Dialog" \
        -variable tk_strictMotif -onvalue 1 -offvalue 0
        pack .strict -anchor c
proc create_temp_file { } {
#  This custom command is supposed to put data in a tempory file
#  and to destroy it self.
    global ct
    global wl
    global JobName
    global FilePath
    variable Thread "create_temp_file"
    global List
    #weak spot pa might crash if directory non existing
    set fileout c:\\temp\\tempct.txt
    set uitvoer [open $fileout w]
    puts $uitvoer "$ct"
    puts $uitvoer "$wl"
    for {set Index 0} {$Index<=$NumberOfContours} {incr Index} {
        set Word [lindex $List $Index]
        puts $uitvoer "$JobName($Word)"
    if [info exists FilePath] {
           if {$FilePath(job) == ""} {
               ErrorMessage
               return
        puts $uitvoer "$FilePath(job)"
    } else {
        ErrorMessage
    flush $uitvoer
    close $uitvoer
    destroy .
proc fileDialog {w ent operation description} {
    global FilePath
    global JobName
    global JobDirectory
    if {$description == "job"} {
       set types {
           {"Task Object"        {.JOB}    {TEXT}}
           {"All files"        *}
    } else {
           set types {
           {"ISO File"        {.ISO}    {TEXT}}
           {"All files"        *}
    if {$operation == "open"} {
        set file [tk_getOpenFile -filetypes $types -parent $w -title "Select $operation"]
    set search_char "."
    set dot_index [string last $search_char $file]
    set first_index [expr $dot_index - 8]
    set last_index [expr $dot_index - 1]
    set trimmed_name [string range $file $first_index $last_index]
        set JobName($description) $trimmed_name
        set search_char "/"
    set slash_index [string last $search_char $file]
    set last_index [expr $slash_index ]
        set JobDirectory [string range $file 0 $last_index]
        set FilePath($description) $JobDirectory
    } else {
        set file [tk_chooseDirectory -parent $w -title "Select UG-nc file directory"]
        set FilePath($description) $file
    if [string compare $file ""] {
        $ent delete 0 end
        $ent insert 0 $file
        $ent xview end
proc ErrorMessage { } {
    global Thread
    set answer [tk_messageBox -message "Really quit Without specifying a Job File?" -type yesno -icon question]
        switch -- $answer {
        yes exit
        no  {tk_messageBox -message "I know you like this application!" -type ok
                if {$Thread == "Main"} {
                   Return
                } else {
                   set Thread "Error"
                   Main
global ct
global wl
global JobName
global FilePath
global platform
global tcl_platform
global Thread
variable NumberOfContours $argv
Main
