Telemechanique Advantys Digital output Card STB DRA 3290
Hi All,
I am programming up a system using telemechanique advantys PLCs.  I have a couple of questions that I would like help with?
1. Does anyone have a good summary of how to program these PLCs?
2. Specifically, how do you address in the PLC code the digital outputs on the STB DRA 3290 Digital Output card?
3. Any other tips/tricks/standard code for prgramming these advantys PLC would be much appreciated?
Thanks in Advance
ROMM
RE: Telemechanique Advantys Digital output Card STB DRA 3290
ROMM
Telemecaniques Advantys is not a PLC it is a distributed I/O system. If you are asking how to address the Advantys from the PLC I suggest you look at www.telemecanique.com then select libary followed by technical publications then interfaces & I/O there you will find a list of downloadable manuals.
If you need more help go back to the home page and select your country it should give you contact details for assistance.
