Virtual ground concept of OPAMP
What are those conditions in which VGC can be applied & which are those where it cannot be applied
RE: Virtual ground concept of OPAMP
The virtual groung is used to determine the direction of current flow through the feedback and input resistors [If=Ii], given that the input impedance of the ideal op. amp. is infinity and output impedance is small (in order to achieve maximal gain).
A situation in which virtual ground is not used is when a voltage is applied to both inputs, hence no input is grounded.
May I suggest looking at it this way. An operational amplifier (op-amp) has two inputs which we call the inverting input and the non-inverting input. With an idealized op-amp, which means one having infinite gain and infinite bandwith, in the response of whatever circuit the op-amp is used, the circuit tries to make the inverting input match whatever voltage happens to be applied to the non-inverting input. If the non-inverting input just happens to be at ground, the inverting input is said to be at "virtual ground". I prefer to think of it as a "virtual non-inverting input".
The rub is that no op-amp really has the ideals of infinite gain and infinite bandwidth. To the extent that gain and bandwidth are actually finite, the inverting input will be not quite equal to the inverting input.
I hope this helps.
John Dunn
Ambertec, Inc.
As I was setting up the simple inverting amplifier with an opamp (LM324), with the positive node grounded, the negative node only follows the virtual ground property up to a certain voltage. Any increase that voltage, the virtual ground property fail as well as all the point voltages of the circuit.
Any idea? thanks a lot!!
where, for example: RI=2.7K Ohm, RF=2.7K Ohm. The maximum value of Vin can only be about 4 V. Any higher value will break down the virtual ground rule
In another instance of the same circuit: RI=2.7K Ohm, RF=5.4K Ohm. Maximum Vin can be up to only 2.13V. Again, virtual ground rule will not hold for any higher values of Vin.
Following is the spec of the opamp I used(LM324):
http://www.national.com/ds/LM/LM124.pdf
does anyone know what the open-loop gain of the opamp is?
Thanks again!!
Also, what voltages do you have applied to pins 4 and 11 of the chip? If you are running off + and - 5 Volts supplies, then this is about where you would expect the output to stop following the input.
Open loop gain is partly dependent on your power supply, but a reasonable value is listed on page 3 under Large Signal Voltage Gain.
