Plane not visible
Plane not visible
Plane not visible
If I right click on a plane and click show, the plane is displayed. However if I click in the model area the plane disappears. Why is the plane disappearing? Can I prevent this?
RE: Plane not visible
Just a quick message, check whether planes will show in general.
Go to the 'View' menu and check to see if planes are highlighted, if not, select it, and your plane should show up.
Michael Jan
Thanks Janman that worked.
No problem, that's usually the solution when things disappear from my experience.
