Error in Design Table
Hi.
I am having problem with creating configurations in the assembly using the design table.  My design table includes $CONFIGURATION and $STATE parameters.
When closing the design table, I get the warning, saying "No valid design table instances were found."  However, I made sure many times that my parameters are specified correctly and instance numbers are also correct.
I am using SW2006 SP4.1.  I've never had problem like this, and I've run out of ideas.  Can anybody help me?
I'd appreciate it.
Thank you,
Uka
RE: Error in Design Table
Can you post a screen shot of your design table?
Hi, handleman.
How do I post the screen shot?
I can only post text message using the window provided on the web.... Help!
Thanks.
Deleting line 2 should rectify the problem.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
I've deleted the row 2, but it is still giving me the same error...
I've tried anything I could think of...
See the Help file for Design Tables > Related Topics > Formatting a Design Table
Quote:
By default, cell A2 is reserved as the Family cell. This cell determines where the parameter and configuration data begins. The Family cell contains no text, however, in Excel, the Name Box displays Family.
cheers
Try deleting the current DT and creating a new one.
I usually find it easier to create the first config manually (other than the default) then use the auto-create function to set the DT.
cheers
Thanks a lot, CorBlimeyLimey.
It fixed the problem!!
Uka.
You're very welcome ... and thank YOU for the feedback.
cheers
