Linking text values
Linking text values
Linking text values
I've been away from AutoCAD for a few years, and I was never a master of it in the first place.  However, I have a question on linking text....Can it be done?  From what I can recall I don't think it's possible, but maybe there are tricks that I don't know about.
I've got a situation where a coworker is using AutoCAD, and he has a bit of text on the drawing.  Let's say it's a part number, that part number is displayed in quite a few areas on the drawing, he'd like to be able to change it at one location and have the rest update accordingly.  Is there anyway to make this happen?  I know about atributes and that sort of thing, but not enough to know if this is a situation that they would be helpful.
Thanks for your time.
Chris
RE: Linking text values
Try the FIND command
"Everybody is ignorant, only on different subjects." — Will Rogers
If the part number is a block or an attributed block, any change that you make to either the block or the attributed block will be reflected to those other texts(part numbers).  Do an LI command on anyone of those texts to determine from the history screen if they are blocks, attributed blocks or just plain text.
You can use the LiveLabel reactor for this. But this is an add-on ARX utility not an AutoCAD internal function.
See http://www.xanadu.cz/livelabel
V.Michl
