flitch plate design
flitch plate design
i have a psl beam spaning approx. 21 feet. the beam is 7 inch wide and 14 inch deep supporting a 2x4 wall and roof above. the wall is not centered on the beam. need to add a 1/2 inch x 14 inch flitch plate. how do i determine the number and spacing of bolts required?
RE: flitch plate design
http://www.sda.co.uk/info/sbw/flitch.htm gives more
TonyB SDA UK
http://www.destefanoassociates.com/tech/flitch.pdf
www.SlideRuleEra.net
