Software for Precast Bridge Girder
Can anyone suggest a reasonably priced software package for designing precast bridge girders? Our office does a few bridges each year but not enough to justify an expensive program. I would prefer one where non standard loadings can be used.
RE: Software for Precast Bridge Girder
http://www.lrfd.com/
Leap software's CONSPAN is good but I think is more expensive.
http://www.leapsoft.com/
Both companies offer leasing options for the software.
Some state DOT's also have in-house programs that work adequately and are usually free. You would need to contact them directly to see how to gain access.
http://www.dot.state.fl.us/Structures/proglib.htm
Assuming you have Mathcad and use LRFD this is an option for you. I’m not sure if it handles non-standard loadings, but since it’s in Mathcad you can modify the sheet as necessary for your design.
http://w
Another good resource for LRFD design is Washington State DOT. They have a prestressed girder analysis program (PGsuper) and HL-93 live load analysis program (QCON Bridge). These programs are free to download.
http://www.wsdot.wa.gov/eesc/bridge/software/
I have not used the PGsuper program but have used QCON to run live load for a project I was working on. It worked well.
As MichSt and Tampa suggested the FLDOT mathcad sheet is a good starting point and you could always modify the sheet to use LFD, the design is essentially the same, just the loading changes.
Good Luck.
http://www
