need gear pump details Rated discharge 3000Psi min,8000rpm,1-3GPM
I need supplier details of Gear pump for the following spects
Rated discharge Pressure :3000Psi min,
Speed:8000rpm,
Flow:1-3GPM
thanks in advance
John
RE: need gear pump details Rated discharge 3000Psi min,8000rpm,1-3GPM
try Rotortech
That is a high speed for such low displacement...
3 GPM @ 8000 RPM is 0.000001623 cubic inches per rev...
Sounds like Vickers AeroSpace equipment used on Jet Engines but they are Axial (In Line)Piston Pumps.
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
fluidpower1 @ hotmail.com
http://www.fluidpower1.us
