Does Halon detection system works with FM200
Could someone please tell me, is it possible to maintain fire detection system (i.e fire control panel, detectors) used in halon system to be reused with FM200 system.
your help will be appreciated.
RE: Does Halon detection system works with FM200
Based on your post I'm assuming you have verified compatibility of the nozzles for the selected hazard and design conditions and appropriate pipe sizing for your hazard?
I need to check NFPA 72 and 2001 tomorrow, and I will do that in the AM before I can offer a concrete answer. Sorry I can't do it any earlier.
thanks
It all comes down to liability and not so much as to technical.
http://da
