own diff() function: Y= X2 - X1.....Xn+1-Xn
is there anybody who knows how to change the matlab included diff() function to the following form:
I just have created an m File where I do this manually seperate from diff() like:
for(c=1:1:length(x)-1)
    Y(c)=[(x(c)-x(c+1))];
end
The sample code above takes a lot of time. For my data file (including 1,750,000 values)it takes about 10 hours. The matlabs own diff takes a piece of this time. Hope you can understand my request in this matter.
Thanks in advance.
PsyDelic
RE: own diff() function: Y= X2 - X1.....Xn+1-Xn
As long as you have enough memory, I would think you can speed it up by doing it as a vector operation, rather than a loop.
Can you achieve it using ML's buitin, surrounded by a couple of flipud's?  Otherwise it's MEX all the way.
You need to figure out how to use the built-in functions.  They run hundreds of times faster than a explicit loop.  The simplest solution is to create a reverse order index that you can use as one of the columns in your dataarray, sort on the column to reverse the order of the data and perform the usual diff.
TTFN
This has been cross-posted to CSSM.  Kind of annoying really, choose your forum!
CSSM?
His profile only shows one posting to Eng-Tips
TTFN
Upon further investigation, the slowness of your process is mostly likely because you are dynamically allocating the arrays in the FOR loops.
As stated in the MATLAB help files preallocation significantly improves throughput.
CODE
dirsize = 2000000;
tic
A=zeros(dirsize,2);
Z=zeros(dirsize,1);
for i = 1:dirsize
  A(i,1)=dirsize+1-i;
  A(i,2)=i^2;
end
B=sortrows(A,1);
for i = 1:dirsize
  Z(i)=B(i,2);
end
C=diff(Z);
toc
t=toc
takes 2.4 seconds on a 1.8 GHz P4 with 512MB of memory.
The code creates a 2 column matrix, using the first column as a reverse index, data in the second column.   The matrix is sorted, the second column is extracted and diff() is applied to the resultant vector.
TTFN
Thanks for your replies. I got a solution. I did a reverse Loop. I started with the last item of my array in the following way. It saved much more time. Now I need only a few secs. for it
for (c=length(x):1:1)
y=diff(x(c)-x(c+1));
end
Thank you very much for your help!
Bye
Quote:
CSSM?
comp.soft-sys.matlab
This is the one-stop shop for Matlab duscussions - a USENET group that's been alive since c. 1993.  All the experts reside there.  Sometimes engineering questions stray here too.  Othertimes there's the boring cross-posting activity.
SomtingGuy gave you the best answer.  Did you try it?  Your request and your example did not match.  I assume you wanted something that achievedyour example program.  Flipping the vector before and after the call to the built in diff will do exactly what you want, and most efficiently, as SmetingGuy stated.
Actually Duane Hanselman gave the best answer in CSSM:
-diff(x)
