etabs plus and sequential construction case
I am designing a building without a column in the first story. I´ve found that if I run an elastic analysis and then I define a sequential construction case, etabs plus v.909 makes an analysis and gives results that makes sense. But I am not sure that etabs plus results are correct, because manual refers to etabs nonlinear when you ask about sequential construction. Could some body tell me more about this topic.
RE: etabs plus and sequential construction case
door to the sequential analysis if you define the
dead-sq after you run the static analysis, that is the
statement I wrote by first. Please follow this steps
with any model you have: delete any dead-sq case, run
static analysis, define a dead-sq case, run the
sequential construction case, and you will obtain this
analysis run log:
Program ETABS Version 9.0.9.0 File:modelo secuencial similar al tutorial.LOG
BLOQUE 5
B E G I N A N A L Y S I S 2006/08/18 22:58:53
MAXIMUM MEMORY BLOCK SIZE (BYTES) = 31.962 MB
E L E M E N T F O R M A T I O N 22:58:53
NUMBER OF JOINT ELEMENTS FORMED = 79
NUMBER OF SPRING ELEMENTS FORMED = 0
NUMBER OF FRAME ELEMENTS FORMED = 159
E Q U A T I O N S O L U T I O N 22:58:53
TOTAL NUMBER OF EQUILIBRIUM EQUATIONS = 207
APPROXIMATE "EFFECTIVE" BAND WIDTH = 33
NUMBER OF EQUATION STORAGE BLOCKS = 1
MAXIMUM BLOCK SIZE (8-BYTE TERMS) = 6447
SIZE OF STIFFNESS FILE(S) (BYTES) = 51.191 KB
NUMBER OF EQUATIONS TO SOLVE = 207
NUMBER OF STATIC LOAD CASES = 4
NUMBER OF ACCELERATION LOADS = 6
NUMBER OF NONLINEAR DEFORMATION LOADS = 0
J O I N T O U T P U T 22:58:53
G L O B A L F O R C E B A L A N C E R E L A T I V E E R R O R S
PERCENT FORCE AND MOMENT ERROR AT THE ORIGIN, IN GLOBAL COORDINATES
LOAD FX FY FZ MX MY MZ
DEAD 3.26E-15 .000000 1.18E-13 0.478953 6.80E-14 0.015486
TRIBUTAR .000000 .000000 .000000 .000000 .000000 .000000
SX .000000 .000000 .000000 .000000 .000000 .000000
SY .000000 .000000 .000000 .000000 .000000 .000000
SPEC FX FY FZ MX MY MZ
E L E M E N T J O I N T - F O R C E O U T P U T 22:58:53
NUMBER OF JOINT ELEMENTS SAVED = 79
NUMBER OF FRAME ELEMENTS SAVED = 159
E L E M E N T O U T P U T 22:58:53
A N A L Y S I S C O M P L E T E 2006/08/18 22:58:53
BLOQUE 5
B E G I N A N A L Y S I S 2006/08/18 22:58:54
E L E M E N T F O R M A T I O N 22:58:54
L O A D R E - S O L U T I O N 22:58:54
E L E M E N T J O I N T - F O R C E O U T P U T 22:58:55
A N A L Y S I S C O M P L E T E 2006/08/18 22:58:55
BLOQUE 5
N O N L I N E A R S T A T I C A N A L Y S I S 2006/08/18 22:59:28
NONLINEAR STATIC CASE = DEAD-SQ
CONTINUE FROM PREVIOUS CASE = 0
LOAD CONTROL TYPE = FORCE
METHOD TO USE WHEN HINGES DROP LOAD = UNLOAD
TYPE OF GEOMETRIC NONLINEARITY = NONE
SAVE POSITIVE INCREMENTS ONLY = YES
MINIMUM NUMBER OF SAVED STEPS = 1
MAXIMUM NUMBER OF SAVED STEPS = 50
MAXIMUM NUMBER OF NULL STEPS = 50
MAXIMUM NUMBER OF TOTAL STEPS = 200
MAXIMUM NUMBER OF ITERATIONS PER STEP = 10
RELATIVE FORCE CONVERGENCE TOLERANCE = 0.000100
RELATIVE EVENT TOLERANCE = 0.010000
STAGE NUMBER = 1
ENTIRE STRUCTURE IS ACTIVE = NO
CHANGES TO ELEMENTS IN STRUCTURE = NONE
STEP 0
STEP 1, INCREMENT = 1.000000, SUM = 1.000000, MAX = 1.000000
Unbalance/tolerance = 4.39E-12, Iteration 1 converged
Saved as Output Step 1
TOTAL NUMBER OF CONVERGED STEPS SAVED = 1
TOTAL NUMBER OF CONVERGED STEPS NOT SAVED = 0
TOTAL NUMBER OF NULL STEPS = 0
TOTAL NUMBER OF ALL STEPS = 1
TOTAL NUMBER OF ITERATIONS CONVERGED = 1
TOTAL NUMBER OF ITERATIONS DISCARDED = 0
FOR CONVERGED STEPS ONLY:
AVERAGE NUMBER OF ITERATIONS PER STEP = 1.00
STAGE NUMBER = 2
CHANGES TO ELEMENTS IN STRUCTURE = ADD ONLY
STEP 0
Unbalance/tolerance = 6.65E-11, Iteration 1 converged
STAGE NUMBER = 3
STEP 0
Unbalance/tolerance = 6.47E-11, Iteration 1 converged
STAGE NUMBER = 4
ENTIRE STRUCTURE IS ACTIVE = YES
STEP 0
Unbalance/tolerance = 4.59E-11, Iteration 1 converged
STAGE NUMBER = 5
STEP 0
* * * W A R N I N G * * *
THE APPLIED LOAD IS ZERO IN NONLIN-STATIC CASEDEAD-SQ ,
THE ANALYSIS WILL PROCEED BUT THE STRUCTURE WILL NOT BE LOADED
Unbalance/tolerance = .000000, Iteration 1 converged
TIME FOR INITIALIZING ANALYSIS = 0.03
TIME FOR CONTROLLING ANALYSIS = 1.14
TIME FOR FORMING STIFFNESS MATRIX = 0.07
TIME FOR SOLVING STIFFNESS MATRIX = 0.24
TIME FOR CALCULATING DISPLACEMENTS = 0.00
TIME FOR DETERMINING EVENTS = 0.00
TIME FOR UPDATING STATE = 0.04
TOTAL TIME FOR THIS ANALYSIS = 1.52
A N A L Y S I S C O M P L E T E 2006/08/18 22:59:30
