Bolt Screw Lift Loads
How do I calculate the vertical lift capacity of a 1-inch dia. 304 S.Stl. UNC bolt?
The nut & bolt act as a lifting device and will be torqued by hand.  The action of the pitch will raise the load.  At what point should we worry about load binding?
RE: Bolt Screw Lift Loads
If the nut and bolt are of the same material and unlubricated, the threads will gall and bind immediately.
Mike Halloran
Pembroke Pines, FL, USA
