inserting items into dynamic blocks
Anyone know how to add items to a dynamic block that is already created in AutoCAD 2006/2007? I have a fairly complex block and the only way I can seem to add items to the selection set is when originally creating the block. When doing that of course, I lose the dynamic properties. For example, in a machine assembly, I forgot to add some bolts. I already added dynamic moves and lookups. How can I add the bolts to the block now? The old "edit block in place" editor allowed you to hit the "+" icon to add items to the selection set, but editing using that method doesn't seem to be an option once dynamic.
RE: inserting items into dynamic blocks
http:/
"Everybody is ignorant, only on different subjects." — Will Rogers
