Solidworks 2001+ No Drawing Template?
I installed SolidWorks 2001 Plus. I have the three template files Assembly.asmdot, Part.prtdot, and Draw.drwdot in the /data/templates folder. When trying to start a new file I only see the assembly and part templates. In addition under the default templates I only see the default for the assembly and part and no option for the drawing templates.
If anyone can let me know how to fix these problems it will be much
appreciated.
appreciated.
RE: Solidworks 2001+ No Drawing Template?
First things first, Lets verify something
Go to TOOLS/OPTIONS/SYSTEM OPTIONS/Default templates.
On the right side of the diaolog box, there should be three text boxes that are file names and paths for specifice templates. Make sure that they are all filled in.
By default that directory for templates is C:\Program Files\SolidWorks\data\templates\
verify that all three are completed and that the drawing text area shows drawing.drwdot
regards
JOn
This is one reason I put my custom templates and formats off on the network drive. All you have to do after an install is redo the file pointers.
Our VAR suggested the new version should be installed in its own directory so we still have access to the old version.
Crashj 'oops' Johnson
