plasma heat load relationship
i have an aluminum plate facing a 3kw plasma source. how can i translate that 3kw plasma source into some sort of heat flux/load so that i can do a thermal model of the plate?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: plasma heat load relationship
Keith Cress
TTFN
In any case, I would then suggest that you look at competitor's systems to determine whether the heat load is a issue or not.
Small plasma reactors that hold 1 lot of wafers are completely devoid of any heat exchanging in the chambers.
TTFN
