Dwg View Problem
Dwg View Problem
NX4.0.0.25
Dell Precision PWS670
Windows XP x64
NVIDIA Quadro FX 4500
When I start a drawing and add a view, the view bounds are huge and nothing shows up. A projection off of that initial view will display properly, as will any subsequent projections.
Before I run it by GTAC, I thought that I would check if anyone here has come across this.
Windows XP x64
RE: Dwg View Problem
I'd just send it in to GTAC and let them sort out their mess. I've grown pretty tired of all the broken stuff in NX and I don't even bother trying to find workarounds anymore. I figure if they can't release something that works, then they can spend the time trying to figure out why it doesn't work....I'm not the one getting paid hundreds if not thousands of dollars a month in maintenance (from EACH NX user).
Good luck, bud.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I have clipping bounds toggled off in my defaults so I don't have the extra step.
