Schmitt Trigger in Simulink
Is there an actual block in simulink for schmitt trigger or a simple way to simulate it?
I dont seem to find anything on mathworks.com
RE: Schmitt Trigger in Simulink
Try:
http://ww
or
A simple model built from the description given at:
http://hy
signal path:
*Vcc --> + Vref --> - Vin --> sign() --> *Vcc
L__>Vout
pseudocode
Vout=(Vref+Vcc)-Vin
Vcc=sign(Vout)*Vcc
I hope this helps.
BSK
Drop me a line if the relay block fills your need and if it doesnt please tell me why, i always like a good puzzle.
BSK
It seems to work fine for now and I didn't attempt your pseudo code (not that I understood it clearly but Relay seems to work).
Thanks a bunch.
