Power Calculation for VFD Pump
How do the affinity laws behave for %BHP in relationship to %flow when the head is constant?
RE: Power Calculation for VFD Pump
You should be able to plot it on a pump curve to determine what will happen to the bhp.
When you change the speed of a pump, head will never stay constant. If you are controlling the pump speed by a pressure controller, then you will not get much benefit out of a VSD scheme.
