Cannot find fixed entity...
RE: Cannot find fixed entity...
What happens if you select a different edge or face?
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
CBL,
I don't understand what you mean by "What happens if you select a different edge or face?" I don't get any option to do that.
the message only comes up when I attempt to flatten the part.
When flattening a SM part, you need to specify which face or edge should remain static ... a datum if you will to flatten the bends in relation to.
The message reads, "Cannot find fixed entity in Flat-Pattern feature. Please do edit definition of Flat-Pattern feature and select a fixed face/edge."
Have you done that?
cheers
Also, the image shows that you are trying to create an Edge-Flange, yet you state that "the message only comes up when I attempt to flatten the part.".
Can you better explain exactly what you do to get to this point.
cheers
I can't see the whole part, but looks like the flange may interfere with the adjacent side when flattened. It's why it can't flatten.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
well, I don't see the message anymore when flattening. I took a snapshot of the message in hopes of understanding why it happened. so I can't reproduce the problem.
this is what I'm understanding. I have to edit the feature (in this case the flange) and fix an edge in it, so the swx would bend around it?
If you can't reproduce the problem, does that mean you can now flatten the part?
cheers
the interesting part is the after OK a couple of times it flattened anyway.
