excel macro
excel macro
excel macro
Hi
when I run my macro for excel in Visual basic I find this error:
Runtime error 1004
Method 'Range' of object' - Global' failed
I think the error is in this statement:
y = funct("abc", Range("abc"), 1)
The function has been defined as follows:
Declare Function funct Lib "hello.XLL" (ByVal sheetName As Variant, ByVal Range As Variant, ByVal lockFlag As Variant) As Long
I tried y = funct("abc", "Range(abc)", 1)
but then the program is working and result is wrong
Could you help me fix this problem.
bigb
RE: excel macro
Firstly, 'Range' us a reserved word and you should not use it as an argument name in the Function declaration. Try using 'Rng' instead.
Function funct(ByVal sheetName As Variant, ByVal Range As Variant, ByVal lockFlag As Variant) As Long
Secondly for the function call:
to work, "abc" must be a named range in the workbook - and from the look of your function, should most likely contain a string...
Good luck
