Modern jets scaled versions
Hi all,
Is there any particular reason why people do not design scale down versions of modern jet fighters (F-16, F-18, etc.)?
I'm sure I am not the only one dreaming of my own small version F-18 Super Hornet.
Thanks in advance for your input.
RE: Modern jets scaled versions
Do you mean an absolute scale model? that would still fly? and carry a pilot?
It would cost hundreds of millions to develop and crertify, and millions to build, and a lot of training to fly.
Or do you mean something less ambitious?
Cheers
Greg Locock
I was thinking along the lines of a long-ez in terms of construction and configuration. Maybe twin wankels on the back driving counter-rotating props on a single shaft to keep the profile of the design(except for the props).
Of course I do not know how the aerodynamics, cg, etc would play out, but I am sure it can be worked out.
It is just a thought that came to me while watching a canard aircraft video.
http://www.swbturbines.com/swb-35.htm
http://www.asiascalerc.com/links.htm
http://www.skymasterjet.com/22.htm
I haven't actually seen one fly in person, but I've seen the videos and it kicks butt compared to any fan propulsion:
http://www.rcarf.com/f16s.wmv
htt
http://www.airpacmodels.com/skymasterfiles/f22.wmv
Prices are in the low to mid-thousands...
TTFN
Again it's just a thought.
Cheers,
Eddy
Miami, Fl.
So scratch the F16.
Say you went and built a scale F4, how would you learn to fly it? You'd have to first train in a swept wing jet trainer like the T38.
What about testing? Would you do it yourself, after having flown say a T38 and maybe gotten some hours, at best, in a privately owned Phantom? Would you get a real F4 driver to test it for you? Would they be crazy enough to try it? :)
If you want to fly a jet fighter lookalike, this is your best bet:
http://www.viperjet.com/
_______________________________________
Scientific/Engineering Code Exchange:
www.solvengineer.com
For another $75K, they'll pre-build parts of it for you.
TTFN
I did find however several examples of smaller versions of old fighter aircrafts (P-51, Corsairs, etc).
I also found F/A-18 r/c models using pusher props.
I guess my question should have been, why isn't anybody even trying to design an F/A-18 look alike with pusher propellers?
Cheers,
2. insurance
Wes C.
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Price sounds cheep if it includes a GE power plant with 0 hours on it. I assume the kit does not include the power plant.
Kit does not include the engine, engine installation kit, avionics, instruments, unholstery, paint, or wiring.
TTFN
Scaling down these aircraft may alleviate some of these problems, but it may also exacerbate others. I'd hate to know that I was flying a shape that is inherently unstable even if it's scaled down...
there u go :)
