Annimation software ?
Does anyone know what software is used to make the solidworks screen saver of the engine?  Or what software is used to make professional looking (mechanical) 3D annimations?
RE: Annimation software ?
You can make animations from SolidWorks. You can also import SW models into 3D Studio Max and make realistic animations.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Look into SWX animator, you can do some pretty good mechanical animations like showing real time assembly explosion's, showing mechanical movement of parts, etc... if your creative you can do some pretty amazing things with it, you can also use it in conjunction with photoworks for rendering scenes for animations.
   {o,o}
   |)__)
O SLDWRKZI? Waii!!
Work:Dell Precision 380-PENTIUM D 840-PNY QUADRO FX3450 Drivers 77.56-2GB RAM-SW2006 SP4.1-SW2007 SP0-RHINO 3.0 SP5
Play: Intel Core 2 Duo E6700(3.6Ghz on air)-Intel D975XBX-2GB Corsair XMS-Powercolor X1900XTX-74GB Raptor-250GB Caviar
The engine was created using SolidWorks Animator and PhotoWorks by Brian Hill.  www.bxhdesigns.com
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 6/05/06)
SW 2006 SP 4.0
Hmmm I have tried the Solidworks annimator a bit in the past but didn't have much luck with it.  I was able to create really simple annimations where one part moves at a time, but I've been unable to make multiple parts interact.  Is this possible using solidworks?  Do I just need to do some more learning ?
Luca83... .those annimations are really really cool.  Exactly what I want to do.  Do you need a really powerful machine when doing that in Solidworks?
Sorry Luca83... that compliment was actually meant for rockguy.
Jamaz17,
I suggest getting training for the SW animation. It is very cool.
Robs site has some excellent info.
Yes, the more RAM, best video card, etc, will help.
Chris
AutoCAD 06
I don't have a super computer and produce some good renderings and animations.  More power certainly helps but it's not mandatory.  It just takes longer.
Thanks for teh words ctopher
Rob Rodriguez CSWP
President: Northern
SW 2006 SP 4.0
