Cannot Select Objects
I often cannot select certain objects even after REGEN command. Only way to be able to select them is first use erase or move command, then select them, then move or earase them, then UNDO.
Or else I have to reopen the file.
Is it the some limitation/bug in AutoCAD Map3D 2005? Just wondering if anyone else had faced same problem.
RE: Cannot Select Objects
Make sure under the options>>selection options that the options are set how you would want. Just a shot in the dark.
"Everybody is ignorant, only on different subjects." — Will Rogers
See if there is a drive update for your video card.
