ASME 300lb flange vs. SAE Code 61 Flange
What is the pressure rating on a 4" ASME 300 lb flange and other than dimentional information, can they be used in a hydraulic application under similar conditions?
RE: ASME 300lb flange vs. SAE Code 61 Flange
Function of temperature
Mike
...and material (cs, ss, etc.)
