Papermill machine need a highly effective "anti-corrosion" solution
Hello Everyone...
We are looking for a higly effective corrosion control on a papermill machine.  The frame is already corroded but we taught we could apply as a base coat the Loctite Extend Rust Threatment.  But we need something else to protect this one too as it is suppose to be easily damaged.  So we are looking for a paint that can sustain heavy humidity and high temperature.  There is also "whitewater" all around.
In bonus...  The paint must dry and "cure" fast enough as we need to do the corrective action in a short period of time.  Let's say in a shut down.
What about those army boat...  They should use a pretty good paint but I don't know about the cure time...
Many thanks
