wheel torque at aero limits
I've been able to determine that with a rear wheel torque of 322ft/lbs my speed limit is 207mph.
All factors being equal:
cross section 5.8385 f^2
cof. of drag 0.6
rolling resistance 0.02
air pres 2124.00424 lbs/f^2
density of air 0.07411 lb-mass/f^3
temp 77
How can I compute what the needed wheel torque is at higher speeds?
Yes all of thee are actual numbers, not a simulation.
cof. of drag 0.6
temp 77
RE: wheel torque at aero limits
F=T*rr
F=1/2*rho*Cd*A*v^2+m*g*Crr
are the formulas you need, in consistent units.
Cheers
Greg Locock
I do have the other two values.
weight = 762lbs
rolling radious = 12.1"
I'm still not sure where to plug these values into the formula you've given. Any help would be greatly appreciated.
cross section 5.8385 f^2=A
cof. of drag 0.6=Cd
rolling resistance 0.02=Crr
rear wheel torque of 322ft/lbs =T
density of air 0.07411 lb-mass/f^3=rho
weight = 762lbs =m*g
rolling radious = 12.1"=rr
speed limit is 207mph=v
Cheers
Greg Locock
let's start with the OP ...
torque is ft*lbs, not ft/lbs.
by torque do you meaning braking toque ?
is "rear" wheel important (for some reason not immediately obvious)
and greg's response ...
i think you were beguiled by the OP's lb/ft, shouldn't it be T = F*rr
then F = Cd*(rho/g) ... because of the units 1lbf = 1lbm*g, or 1 lbf = 1slug*1ft/sec2 (don't you just love imperial units).
then why would the aero drag force act on the ground line ?
the rear wheel torque statement was just to identify the source of the number so that it's known that powertrain losses have already been subtracted from the flywheel brake torque
i thought "rear" as in tail-dragger (the tail wheel at the back of a plane).
i don't think greg's repsonse applies (but i could easily be wrong). greg gave you the aero. drag force for something whistling along at 200+mph, somehow i don't think that's what you've got ... maybe you could explain the set-up a bit more
currently I'm "stuck" at 303.6 ft/sec with 322 ft*lbs. I'm trying to determine how much ft*lbs I'll need at say 308, 311.67, and 315.33 ft/sec.
and T = D*V/(rpm*(2pi/60))
it's a bit of a different question as to whether this torque can be applied to th eground (without skidding).
Cheers
Greg Locock
